allis grain drill
holthauskieran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote holthauskieran Quote  Post ReplyReply Direct Link To This Post Topic: allis grain drill
    Posted: 14 Nov 2021 at 11:36am
rear wheel sprocket  for snap coupler mounted drill . bolts on rear axel to drive drill. 100.  00 plus ship.  785-410-0777
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 11:59am
What is the tooth count? For WD or CA or maybe even 8N? Does that include the mounting plate and special wheel studs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote holthauskieran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 2:02pm
it is a 24 tooth sprocket with wd or ca-c holes , can send pics -cell phone
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 3:07pm
24 tooth sprocket is for at Side dresser/front mounted planter. An All crop drill will use a 12 tooth sprocket on a CA, a 14 tooth on a WD/WD45 and 13 tooth sprocket if it has a 3pt to be used with an 8N.
This is what the CA All -Crop-Drill sprocket looks like.
Edited by PaulB - 14 Nov 2021 at 3:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote holthauskieran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 3:13pm
that must be what i have. my bad. thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 3:30pm
Is your 24 tooth gear a single piece or is it 2 pieces bolted together? The single gear is for the B & C tractors, the 2 piece gear is the CA gear and would need 2 complete gears to drive both sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote holthauskieran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2021 at 4:08pm
mine is one peice. i have two of those. thanks kieran
BobPaulusCentrOH View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 4:34pm
Thanks to Paul B for answering the question.
I have been looking high and low for drive gear for the CA mounted grain drill.
Appreciate the photo.
Thanks,
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2023 at 6:21pm
What’s the part number
