H3 Steering Clutch Discs
randymcc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randymcc Quote  Post ReplyReply Direct Link To This Post Topic: H3 Steering Clutch Discs
    Posted: 10 Nov 2021 at 4:38pm
I am working on a 1963 H3 that sat outside and has not run in 10 years.  Both steering clutches are stuck.  I have disassembled one and it has the bi-metal driving discs.  Can I sand the rust from these and reuse them?  The dozer will be used about 2 hours a month and it will be stored inside.  Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 4:58pm
Not worth the effort IMHO. Tracy
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 12:04pm
I have used a wire cup brush on angle head grinder to clean ones from a Cat. Worked fine. So I see no reason it would not work on yours.
If the drive teeth are showing ware probably better to just get new. General Gear seems to have after market clutch plates for just about all crawlers.
Edited by Ray54 - 11 Nov 2021 at 12:08pm
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 2:32pm
Do the discs meet minimum thickness specs?
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2021 at 4:37pm
I would say it all depends on how rusty they are...some are far worse than others. If minor, I would try sanding them...that's IF they are thick enough...half worn out you might as well just get the new ones from General Gear in Boise Idaho...they'll fix you up with new steels and metallic discs and they'll last a long time...just my opinion...Rick
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2021 at 7:01am
X 2 on the General Gear Boise Idaho recommendation.
Orangeman
This page was generated in 0.081 seconds.
