616 ,720 hp. differance
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: 616 ,720 hp. differance
    Posted: 24 Oct 2021 at 4:38pm
what makes up the hp differance between the ccka and the cckb i know the charging system is differant but that would not make any differance  is it just the carb and manifold?
Bird76Mojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bird76Mojo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2021 at 9:25am
I'm no expert, but being a 616-720 owner, that is my understanding after years of research. The primary difference being a downdraft carb vs a side-draft carb.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2022 at 9:30am
intake manifold is long runner vs short runner as well, air velocity = cfm
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 10:41am
The engines are also spec'd to run at different RPM's.  The CCKB achieves max power with a higher max rpm spec.  I have not known this to be an issue in the tractor world, but if you poke around Onan engine/generator forums, you will find many jokes about wearing a catcher's mitt when running a CCKB, due to the flying rods.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2022 at 11:19pm
i have a cckb engine here i do not even know if it runs or not but i just got gaskets to put the b manifold and carb on
This page was generated in 0.250 seconds.
