Allis Chalmers 7060 Power Shift Valve Body
tthams View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 7060 Power Shift Valve Body
    Posted: 03 Oct 2021 at 9:46am
I was wondering if anyone knew where I can get a powershift valve body for my 7060 tractor? AGCO dealers are asking $2000. Is that normal price?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 12:57pm
Would imagine theres some out in the salvage yards-
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 9:16pm
Thanks. I tried a salvage yard. They sent one that looked good on the outside, but rusty when you tear into it.
Has anyone had one go bad beyond repair?
Edited by tthams - 04 Oct 2021 at 11:26am
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 9:32pm
Not in my experience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2021 at 10:02pm
What is wrong with yours?                      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 6:38am
Well my first tractor I ever bought a year ago (I'm 43 and it's a 7060 powershift) developed transmission problems in October of 2020. I had the tractor split and overhauled from March to June 2021. I was driving the tractor home in June from the overhaul and multiple clutches engaged during the drive home after the tractor was in 6th gear for a few minutes. Here is that post.
https://www.allischalmers.com/forum/advice-on-powershift-troubles_topic181701.html?KW=tthams+7060
The tractor went back to get fixed again, and I was driving it home on Sunday from the shop to put it to work. I was about 2 miles from the home from the 16 mile journey, and it seemed everything fell apart in the transmission again. Any gear I put the tractor into in low or high side would bog the tractor down and want to kill it if I would keep the clutch out long enough. I feel like multiple clutch packs are engaging again. The shop guy was thinking the valve body is shot now, and since we had bad luck with another used one, he cleaned up the original valve body and put it back on again.
So we talked over the weekend, and he is wanting to try a new valve body to the tune of $2000. I already have $11,000 into the cost of the transmission rebuild from the first time. The guy working on it is doing a great job working with me to get this fixed. He use to work for Robinson in the shop, so I want to trust the guy.
The guy left a pressure gauge for me to watch for the C2 clutch pack on the ride home. He said with the clutch pushed in I should see around 25 PSI and zero when the clutch was out. Well after the issue the pressure gauge read zero no matter what position the clutch was in.
With the tractor in neutral gear and in either low or high side when I would let the clutch out it would take the RPMS down around 500-700 RPMS and hold at the new RPM level.
Any advice on the correct path to take is appreciated. I have had this tractor for almost a year, and only got to use it a day in the field. Is has 4300 hours on the tach.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 6:49am
Wow! Sounds like you have my luck. Something is definitaly wrong somewhere. I'm sure it's fixable but have got to figure out cause first and I can't help there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 7:39am
What was the failure the second time around??  The C-2 (reverse) clutch ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 8:12am
I am not quit versed in the transmission language, but the two seals you discussed in the June posting that may have not gotten replaced were actually replaced that went to the C2 clutch. But there is a housing that those go into. When it was pressure tested with air, it had a small leak with the new seals.
The guy was able to get a replacement from a salvage yard. He pressure checked the housing with air, and it held up great he said. He mentioned that on the original cast housing their might have been an internal crack that developed over the year that you couldn't see. He was impressed with the replacement part.
When he test drove it on Saturday he thought it acted up once for a second or two and that is why he wanted to leave the gauge on to monitor. I just don't know how much damage I did to the clutches driving it onto the trailer to get back over to him. I was able to get the tractor to move in 3rd gear high side to load it. We coasted it off the trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 8:13am
In my opinion, I still think foreign material is getting into valve body. At one time there was a shield to cover valve body that helped to prevent debree from getting into valve. NLA.
Cooler and lines need washed out along with filter lines.
Increase size of plunger pin holes will help to prevent plungers from sticking.
Wish you the best of luck.                          MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 8:21am
So from what I am understanding, I shouldn't need to spend $2000, I can just increase the plunger sizes. Would a machine shop be able to do that, or what would I need to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 9:18am
What p/n of transmission filter does this tractor take ??  I agree with Mack, but noth there looking at it. I think the whole system, coolers/cooler lines and all are contaminated causing plungers in the valve to stick. There's also a matter of flyball orifices in certain clutches that could be plugged and flyball springs should have been cleaned and new. If it is a C-2 clutch failure twice, I have another trick you can do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 9:28am
The transmission filter is from Agco and it is 70269856.
I plan on calling the guy at noon time today to see what he has found out. I will update with anything I hear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 9:37am
Wondering is there a machine that will flush the system on a tractor like a tranmission on a car?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 9:33pm
It is not plunger size, it is the pins that  set on top of plungers that push on plungers.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote tthams Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 8:47pm
I just wanted to update the post. We found a 7010 PS with the valve body still in the tractor sealed up that they are going to pull off the tractor an inspect before shipping. No luck on a new valve body.
I have fingers crossed the old valve body is in good shape, and it can get rebuilt with no issues.
Hopefully in a few short weeks I can finally put the girl to work on the family farm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2021 at 8:55pm
So, is there another clutch failure ?? and if so which one ??
