H3 pto |
elec
Topic: H3 ptoPosted: 28 Sep 2021 at 6:35pm |
I have an H3 with a pto. Was told that in d15 with shuttle the pto is not the right speed. My h3 dozer has a shuttle, so does the pto run at the right speed (540)? Would like to run a pull type brush hog with it.
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54694 |
Posted: 28 Sep 2021 at 7:01pm |
Rev it up and put a tach on the pto shaft..
Beam
Joined: 26 Sep 2021 Location: South Bama Points: 19 |
Posted: 28 Sep 2021 at 8:38pm |
The manual states it will run at 540 at around 1650 rpm (I don’t have access to it now to get exact RPM) regardless of gear. I’m going to add the tach on mine in order to ensure mine runs at 540.
1962 H3, WD45, B210
DonBC
Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 947 |
Posted: 30 Sep 2021 at 3:58pm |
I borrowed a H3 with a pto and I used a 6' bush hog type mower with it with no problems. I also had a H3 LB and with no pto. I installed a hydraulic motor on the bush hog and used the hydraulics for the backhoe to drive it and it worked well also.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4573 |
Posted: 19 Oct 2021 at 7:58pm |
H-3 PTO has a gear box at the rear which corrects the PTO to standard 540 when equipped with the shuttle. D-15, I-60/600/615 does not so has non standard PTO speeds
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 10 Nov 2021 at 11:18am |
This is what's on my HD 3 , let's say if a guy had a extra unit what would a good working PTO Unit be worth .
