7050 rear axle needed
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: 7050 rear axle needed
    Posted: 16 Sep 2010 at 3:54pm
OK, my 7050 has extended axles and had axle mount duals on it when I bought it and the previous owner ran it with one loose hub and ruined both the hub and the axle. Anybody know a source for a good used axle and also dual hub? What other model tractors might work? Thanks. Lonn
Wink
I am a Russian Bot
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2010 at 7:47pm
Lonn i would have a 7580 with long axles i do not know if they are the same size but i can check and see, also have a hub for it also,
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2010 at 6:09am
Thanks Troy. If had to bet it would be that they are a bigger and maybe longer axle. I'll have to go measure my axle diameter. I think they are 3 5/8" off the top of my head.
Edited by Lonn - 19 Sep 2010 at 8:23am
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 8:23am
Troy, they are 3 5/8".
Wink
I am a Russian Bot
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 11:08am
Lonn i have a rear diff. and range transmission ffom a 7060 ps. i can pull an axle if needed and i think i have a dual hub but need to check on that  what is length of axle from final drive to end of axle?   im in north central mo.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2010 at 12:09pm
7580 axle housing is shorter, I think 7050 is the only one that used the 3 5/8 axle in the long housing, 7045 , 7060 ect. had 3 3/4 or 4"  You could use the assembly from one of those tractors.  Pretty sure the 3 5/8 axles had a different seal and wear sleeve setup.
