Allis Chalmers 175 hydrolic pump |
Post Reply ![]() |
elec ![]() Bronze Level ![]() ![]() Joined: 23 Nov 2020 Location: mi Points: 86 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Sep 2021 at 6:42pm |
My 175 has a pump on the side, I've seen others that have the pump on the motor instead. Anybody know what year they switched? I'm looking at buying another 175 and it has the pump on the motor.
Thanks |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22071 |
Front pump began at s/n 175-2035 in late 1973.
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
Cost reduction.... changed pump eliminated bevel gear hollow shaft, along with power steering change= $250 per tractor we were told savings plus less assy time.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8658 |
$250 was real money back then
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Did the front axle change at the same time as the pump or prior?
The change made the front support (under the radiator) a hollow box weldment, instead of a casting with steering gears inside. It then housed the hydraulic pump mounted inside of it. The wide front axle design changed and a narrow front axle/single front wheel were no longer available. The GPM's of the hydraulic pump were reduced about 10% or so because of direct drive/engine speed, where the old system was a speed up drive.
Post Reply ![]() |
