Power director delete for 200 |
200puller
Joined: 28 Aug 2021 Location: Edinburg va Points: 3 |
Topic: Power director delete for 200Posted: 28 Aug 2021 at 4:39pm |
Is there any way to delete the power director from a 200 found out it was my problem with slipping and wondering if there is a gearbox to do away with this problem thanks in advance
brad durst
Joined: 20 Aug 2018 Location: richland center Points: 85 |
Posted: 08 Sep 2021 at 11:03am |
dennis at fvp has a manual shift couplers that he had made. works well thats where i got mine
DougG
Posted: 09 Sep 2021 at 5:56pm |
Id be interested in how this is done - pics would be great
brad durst
Posted: 09 Sep 2021 at 6:28pm |
i never took pictures. i can if i have it apart again. its basically the same as years ago when they would take the power director apart and use nickel rod and weld the two gears together you have to machine the outer hollow shaft tho. the ones dennis has are made out of billet. i think there are pictures on face book on the allis pullers sight. i thought i took pictures but if i did i cant find them. my buddy has been running his for a couple years now.
DougG
Posted: 11 Sep 2021 at 10:00am |
Ok thanks for the info
KevinON
Joined: 07 Dec 2009 Location: Schomberg, ON Points: 810 |
Posted: 08 Jan 2022 at 6:23am |
So can you still shift with this set up? I mean shift manually when stopped?
brad durst
Posted: 21 Jan 2022 at 2:30pm |
yes it is a manual shifting coupler that can only be shifted with the engine off
DougG
Posted: 21 Jan 2022 at 2:51pm |
Like some pictures !
brad durst
Posted: 22 Jan 2022 at 2:59pm |
DougG
Posted: 23 Jan 2022 at 9:26am |
Hey thats neat, thanks
estout81
Joined: 15 Mar 2022 Location: Utica Ohio Points: 34 |
Posted: 27 Mar 2022 at 2:24pm |
I made a power director delete back in the late '70's that worked well. Would post pictures if I new how but, I' new to this forum.
DougG
Posted: 27 Mar 2022 at 2:32pm |
Youll figure it out - keep trying
estout81
Posted: 27 Mar 2022 at 3:17pm |
estout81
Posted: 27 Mar 2022 at 3:19pm |
DougG
Posted: 27 Mar 2022 at 3:46pm |
Looks great! Let's hear some history on this design!
estout81
Posted: 27 Mar 2022 at 4:13pm |
Doug G, I designed and built this unit back in 1976, I think. Gettin' old and can't remember! It was an 180 that I built for a local farmer. He called it "Little Allis. Won state and national championship in I think 1978. If you look at the front end you will see a modified Oliver 60 front end. Later had to make a wide front due to rule changes. I was also the first to put a Bosch inline pump in place of the rosamaster in the stock location. The power director shifter is a sore subject for me. That's another story! Em
DougG
Posted: 27 Mar 2022 at 7:14pm |
Wow! Very nice! Thanks for the info! Bet that 301 was singing a nice tune!
NEVER green
Posted: 28 Mar 2022 at 10:30am |
Inside splines, nobody around here locally can do them. Looks nice.
2-8050 1-7080 6080 D-19 modelE & A 7040 R50
DougG
Posted: 28 Mar 2022 at 6:38pm |
Emerson, what was you guys using for the engine clutch back then ?
