Restoring an old hd4
Foobarbigtime View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foobarbigtime Quote  Post ReplyReply Direct Link To This Post Topic: Restoring an old hd4
    Posted: 07 Aug 2021 at 3:48pm
Good afternoon,. Thanks for the add!
I'm looking for a list of parts for my old hd4 and I'm not having much luck. Anyone have any ideas on how to get the following list of parts?
2 x 232727 Spacer
2 x 229113 Snap ring
4 x 227598 Snap ring
4 x 237929 Shim
2 x 235440 cup
2 x 235439 bearing
2 x 0923584-1 O-ring
2 x 244787 Spacer
2 x 22584 cup
2 x 4251113-5 bearing
2 x 239238 seal
2 x 0237047-6 seal
2 x 1003749-7 Banne Assembly
2 x 0254685-1 Clutch assembly
2 x 225152 pin lock
1 x 233246 Rear cover gasket
2 x 1003344-7 oil seal
2 x 0606897-7 bearing
2 x 209897 bearing
2 x 227678 cup bearing
2 x 222214 cone bearing
2 x 0923584-7 seal cap
2 x 218648 shim
2 x 237929 shim
2 x 247874 gasket pan
2 x 0252653-1 shaft
2 x 233893 bearing
4 x 233906 clip
Thanks ahead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 11:04pm
All those bearing and seals should be found at a bearing supplier - standard industry parts . Other items could be harder but  MinPar might have some or old AC dealer might be able to locate
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2021 at 11:43pm
All Allis numbers need a 7 in front of them. And need to be 8 digits long
tits tyres and tracks
they all cost you money
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 2:56pm
I am still have the 2 shafts  0252653-1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Foobarbigtime Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2021 at 6:16pm
I picked up a parts manual from a&I and all the parts are like I listed. Would you ship the shafts to Canada? How much would you want for them?
This page was generated in 0.344 seconds.
