Military Hummer ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Military Hummer ??
    Posted: 25 Jul 2021 at 5:42pm
Not sure where to put this, but what diesel engine was/is under the hood of a TRUE military machine ? Did that engine carry on to the "civilian" version  of an H1 ?
By "what engine", I'm asking about manufacturer Wink . Thanks
Edited by FREEDGUY - 25 Jul 2021 at 5:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 5:46pm
Standard GM either 6.2 or 6.5 Diesel.  Fuel and electrical components are different Mil to Civil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 5:52pm
Thanks , a guy I was working for today talked about the "military" wanting to see if the Hummer could run on AV fuel to facilitate "fueling logistics" in various parts of the world Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 6:11pm
Diesel, straight diesel.
Only the Deuce and halfs with the multi fuel engine could utilize different fuels.  Were a PITA to do so with, had mix charts for oils gasoline grades alcohol diesel and gear lube.  NONE of which ran as good as straight diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 6:25pm
thanks for the info !!
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2021 at 9:26pm
Oldest son was an Army Wheeled Vehicle Mechanic. He told me the Hummers he worked on were 6.2 G.M. Diesel. All Military Vehicles burned JP8 aviation fuel same as Helicopters and M1 tanks. He said the Hummers were all underpowered before they armored them. Youngest Son who was a Cavalry Scout and Hummer Truck Commander in Iraq said their Up Armored Hummer they had to Rev the engine just to run the radio. And when fully loaded with Ammo and a 50cal machine gun in the roof he said it would hardly pull itself!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 6:11am
Hummer = Vehicle designed by committee, everyone want this and wanted that but they forgot the upgrade package (the power to get it up the grade). In the initial stages of planning the Hummer was to use a Deutz turbo/diesel. That idea was scrapped due to to not being made in America.
   I know someone that got one of the first ones available for civilians, it was massively underpowered and got the worst MPG of anything short of a tank.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 8:40am
military hummers had a GM 6.2 later license built by AM general.  The Military ones used a redblock casting they were better than the GM produced ones use in the GM trucks. I drove them all over in the desert and they were underpowered before up armor. we never up armored ours they were used as flightline transportation and while we were condidered in theater we were a long ways away in Saudi. the civilian ones were equipped with 6.5 and later 6.5 turbos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 8:09pm
The AM General facility is 17 miles SW of my home as a crow flies Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 8:47pm
i have a burb i put a military diesel engine in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2021 at 8:54pm
Was it a "fairly" easy swap ? What did you do with the fuel pump in the original tank ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 1:13am
it was just like putting in any other diesel engine. my burb was a diesel before. had the 6.2 in it, got over 400,000. miles out of it's original engine. the new to me diesel engine came out of a Chev truck from the military. it has under 50,000 miles on the new engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 7:24pm
Thanks, I "kind of" read it that you swapped a diesel for a dead gasser Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2021 at 10:15pm
sorry if i confused it.
