Gleaner M2 Grain head
dnel45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner M2 Grain head
    Posted: 13 Sep 2010 at 7:05pm
I have a 18' Gleaner grain head, serial number LMF294761L and I was looking to add poly pads to the bottom.  The metals are getting wore out.  Is this head known as the "Series II" header?  I am seeing a poly kit for Gleaner Series II headers and the series II headers I am finding on the internet look about the same as mine.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 7:10pm
Oh the approximate year I believe is around 1978.  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 8:36pm
If it is a 1978 it is a series 2....series 3 came in 1983 if I remember right. If there are feathering sheets between the sickle and the header floor that you can flip forward to "open" them, it is a series 2.  Series 3 are known as the "flat bottom" feathering sheets as they are an integrel part of the header.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dnel45 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 8:51pm
well it has a black frame and reel, not the orange one, so im assuming it is at least a series two.  the feathering sheets you are talking about move up and down with the sickle knife, correct?  thanks.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2010 at 10:19pm
I had a series 2 M grain head and I added the plastic to the bottom of the skid plates that ride the ground.  I purchased a chunk of white plastic and cut and made them fit.  It worked out well and had very little cost.  I got the material from this place.   http://www.eflighting.com/default.html  They are out of Hooper Ne.
