Newbie. Thanks for the add. Question
Tim Moisio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim Moisio Quote  Post ReplyReply Direct Link To This Post Topic: Newbie. Thanks for the add. Question
    Posted: 08 Jul 2021 at 9:58am
Hello all.  I am located in Northeast Ohio 60 miles east of Cleveland along the beautiful shores of Lake Erie.
I have looked at a JD 350B and passed on it.  Will be looking at a Cletrac and a Cat D2
Also, I will be looking at a HD5 soon.    I found steering clutch videos on HD6, but none on HD5.  I like that you dont need to break track.
What are the differences from the HD5 and HD6?
 Looking for something to keep at the farm that we just bought.  I am mechanically inclined, but I am not as young as I used to be........Big smile
Thanks all
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 10:49am
HD5 and 6 basically the same except the engine. same transmission , rear end and finals except later 6 used more splines on sprocket shaft.   6 uses the 4 cylinder 4 stroke buda/allis engine. a  good engine but parts are getting difficult to find.  the 5 uses the 2-71 detroit and parts readily available.
Edited by CAL(KS) - 08 Jul 2021 at 12:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim Moisio Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 2:42pm
Edited by Tim Moisio - 08 Jul 2021 at 2:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim Moisio Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 2:46pm
Thanks CAL. Is the 2-71 two stroke?, as i watched a video of trying to start a HD5 Detroit 2 stroke.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 4:42pm
Until the Series 60 came out all Detroits were 2 stroke
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim Moisio Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 6:37pm
Thanks all. I am going to look at it tomorrow.   I will post pics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 6:40pm
Detroit parts are getting slim for the 53 & 71 series
DD shops are no longer selling DD produced parts where all are aftermarket
Leads to all manner of horror stories.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2021 at 12:29pm
The HD6 uses the same rear cases as the HD5 as well as sprockets , rollers, idler , and track with only truck frame being longer on the HD6,
 Depending on late HD6 the steering clutches were the same in both machines as dry unite but later HD11 clutch friction plates can be installed in either machine giving bi-metal ceramic facings instead of fiber friction discs - a common update used by many .
 Any machine that is over 50 years or 70 years old is going to present a problem in finding some parts but it seems except for track itself there are still parts around for both machines .
