Allis 7000 pto
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7000 pto
    Posted: 04 Jul 2021 at 11:37am
Most of the time I engage the pto on my marron belly 7000 it slams in. Even pushing handle slowly to engage. What is causing this.
  Thanks Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2021 at 7:07pm
Maybe it's normal. What kind of implement ?? Do you have the engine idled down fully ??  I'd be more concerned if it was slipping under load than what you are complaining about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 5:30am
PTO engagement  rpms are probably around 800. I can hear a loud racket from the oil flow when I push the handle ahead. When it does that I can here the slip clutch on the rotary hay rake. Other times pushing handle ahead to turn pto on its nice and quiet, and no noise from slip clutch. I want to use it with Kuhn disc mower. PTO engagement will be around 1500.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 6:37am
Not saying there isn't something going on, but why 1500 RPM engagement speed on the Kuhn mower?? Why not 800 ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 7:50am
That rpm is what I use on my Zetor to mow with, and the mower on start up will pull the engine down. If I used 800 rpm on my Allis it would probably stall it. But the problem is the loud noise of the oil flowing when it slams the pto on. I was wondering the pto spool needed to be looked at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 8:05am
But, you haven't acoually tried it on the Kuhn mower, correct ?? The rake is a low HP/torque implement and the PTO clutch might be a little aggressive on it, but on the mower it may be fine. Try it before tearing the tractor apart and try it at 800 rpm.
Edited by DrAllis - 05 Jul 2021 at 8:05am
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 8:12am
Our hay tedder's clutch had broken springs in it and rattled upon start up. Maybe yours does too? Clutch is at the end of the PTO shaft.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 8:40am
Make sure the cable goes smooth at lower end my be tight
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 8:41am
Id say theres clutch disc issues - really not familar with these but One Hundred series can act like that
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 12:33pm
No I have not tried it on the Kuhn mower yet. But I will today.  The slip clutch on the rake never makes noise when I use the Zetor. First Alvin I'll check the cable end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2021 at 7:44pm
I took the clevis off, and found the lever moves fine, no binding.  The cotter pin holding the clevis pin on has been changed, and was mangled. So I tried adjusting the cable some. Nothing changed. Still sounds like buzz saw cutting steel about 3/4 of the way, but quiet at the end. I hitched the 7000 to the mower, and found I would need shorten the drive shaft about 6". Then hitched the Zetor to the mower and found it comes 8" from the pto. I have not cut it yet. I need to do some measuring to make sure it will work on both tractors. In the picture by the little yellow mark. The plunger is supposed to have up to .020 clearance, not about 1/8". But it made no difference tightening up the clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 12:30pm
The 7000 has two drawbar length holes in the front. Difference between them is probably 3 inches center-to-center.  Short for 540 machines and long for 1000 RPM machines.  I have no idea why that implement won't connect to either tractor...strange.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2021 at 3:06pm
The mower is a 2 point hitch up. On the Allis pto, from detent to detent its 33.5". The Zetor is 43.5" I can't compress it without cutting it to get it on the Allis. Right now I have 12" of overlap on the shafts when its on the Zetor. I'm not going to cut it and have 5 or 6" of overlap, should I need to put it back on the Zetor. I've just ordered a shaft to fit the Allis. There's a guy two miles away that has the same tractor and mower. I'm going to pay him a visit. Thank you for your help Dr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 5:36pm
Finally I got a chance to look at the 7000 that's nearby. But first I want to start with a couple days ago. My son is in the cab, and I watch him slowly bring pto in all the way. The pto turns slow, then almost stops, then spinning. But then I'm hearing bad bearing sound coming from the pto shaft at the back of the tractor.  So I walk around and tell him I'm going to the valve body for the pto. He tells me he can here that racket upon engagement, then quiet. So he engages the the pto, and I can hear that hydraulic squealing sound coming from the pto valve body. So instantly I'm thinking there's something gone bad in there. But then in the next second I'm hearing a bearing that is chucking bad, and does not sound good at all. So the sound is just traveling down the shaft. I'm thinking the squealing sound is the hydraulic oil going by the spool valve, has it tries to turn the shaft. The bearing is that bad. The other tractor makes absolutely no noise  with pto engaged. In the picture the bad bearing sound is coming from the area where the neg battery bolts on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 5:57pm
All model 7000's make and have a rattling noise when the PTO is running when the engine is below say about 15 to 1600 RPM. This is common and NORMAL.  The warmer the hydraulic oil, the more noise you will hear.  The reason for the noise is a metal (tin) oil baffle that surrounds the lower PTO output gear. It just hangs in there and this is the way they all are with the maroon chassis. Pretty sure black chassis does it as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 6:28pm
Interesting, because the other tractor is quiet. So that blows my theory. So is removal of pto valve body the next step.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 6:32pm
The "other" tractor is an AC 7000  ???   To xplain a little better, my noise goes away above the 15 to 1600 RPM speeds and you don't hear it in the cab if the cab has floor mats and good cab isolators.
Edited by DrAllis - 14 Jul 2021 at 6:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 7:31pm
Yes the other tractor is a late 1978 maroon 7000. Mine is a 1976 model. I never knew it made the chucking noise till I was in front of it. But the squealing noise is not heard in the other tractor, nor the chucking noise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 6:40pm
You were right Dr about the noise going away at higher rpm. I brought mine up to 1100 rpm. That's what rpm his was doing when I got in the cab to try the pto handle. There's absolutely no chucking bad bearing sound at all. So I just have the squealing sound from the pto valve body. Can things go bad real quick when that is pulled off the tractor. Thank you for all your help Dr.
  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 6:49pm
You think you have a problem with "harsh" PTO clutch engagement. Quit worrying about whatever hydraulic squeal/noise you are hearing. You have two nearly identical tractors. Hook each one up to the implement you think you have a problem with and compare them for clutch engagement. I'm not there standing next to your tractor but I'm not yet convinced you have anything to worry about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2021 at 7:21pm
All right I'll get over it, lol. Thank you again.
 Tim
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2021 at 9:12pm
we have several 7000 's with high hours.  We are finding the aluminum valve body is being deformed where the steel spools slide all the time.  You may or may not have an issue as tractors are like motherinlaws  no two are exactly alike. I would pull the modulator valve out and check to see if the bore is perfect and not sticking the valve. If it has a ridge on it polish it out...  That is the valve removed below the inching valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 10:23am
Thanks Tim for your reply. I do want to take the outer part of the valve body off. After looking in my manuals. Only a bunch of oil should come out, not other parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2021 at 9:23pm
#29 and 33 will fall out. Make sure they go back in right places. They do crazy things if lost or in wrong places.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2021 at 3:54pm
Thanks Mack, I'll be watching for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 11:19am
I got the new pto shaft installed, and mowed with it today. It does start the mower slowly, then comes right in. I'll run it like this till fall. Also the valve bank leaked so bad I had to change rags under it every time I used it for raking. I fixed that over the winter. When I was done mowing I felt around the valve bank, and it was dry as a cork leg, lol. It was such a joy to mow with a two wheel drive tractor again. And then not have to unhitch from it.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 1:18pm
Looks like the day she rolled out of the factory.  Very nice.  I spent many hours planting with a 7000 and a  8 row 30 in 5100 white planter.
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 8:42pm
That looks like a picture post card.
Beautiful set up.
Good work Tim! Staying with it & figuring out a problem payed off.
Ray W.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2021 at 8:58pm
Beautiful picture. I have the same mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2021 at 6:19am
Thanks for the compliments guys. Fixing problems in a 45 year old tractor, are like little victories.
 Tim
