Gleaner N7 Question and Thank You
robbieallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robbieallis Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner N7 Question and Thank You
    Posted: 12 Sep 2010 at 9:45am
I am looking at a Gleaner N7, 1979 combine.  It is in fairly good shape.  Was looking for advise and possible prices members thought might be good.  I want to thank everyone for helping me with a lot of questions I have posted.
Rob
Allis 4ever
AndrewGubbels View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndrewGubbels Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 1:08pm
The ones I have seen have been anywhere from $6000 to $15000 for an excellent one. THings to look for that is common points of wear.  Feeder house chains upper and lower. Check the clean grain and tailings elevators for worn through spots and bad chains.  Check all the augers and grain tank bottoms.  Give the belts a looking over.  Also Just take a look at the cage, and helicle bars and cylinder bars.  Check for alot of wear and bent spots in the cage. Just look it over you can spend alot fast getting it back up into shape if it needs these.  Good Luck!!
Andrew
Andrew Gubbels
Gubbels Restoration
orebaugh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orebaugh Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 2:08pm
Cage sweep was a nightmare on ours. We replaced the open cylinder with a closed one. Doubled the helical bars (piggy backed them). New extened concave. New cage. Pryor to that, it was doggy in beans. After these improvments, a real bean eater.                                        Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote robbieallis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2010 at 10:35pm
Thanks for all the wonderful advise, I really appreciate it!
Rob
Allis 4ever
