615 diesel d2200 backhoe won’t start
Green135 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Green135 Quote  Post ReplyReply Direct Link To This Post Topic: 615 diesel d2200 backhoe won’t start
    Posted: 08 Jun 2021 at 11:28am
I’m new hoping someone can help I have a late 60s 615 when I try to start it when it’s just about to catch it seems like either starter disengages or engine shuts down I’ve gone through the wiring new battery rebuilt starter at a dead end
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2021 at 4:33pm
describe more or post a video.........
HD3
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2021 at 7:12pm
Have you bleed the fuel system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Green135 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 11:27am
Yes bleed when I changed fuel filter was running fine then started doing this. I’ve looked in to it more I think it maybe be fuel shut off selnoid gone bad would than cause complete engine shut down ? Wouldn’t it just keep cranking just not start?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 12:42pm
You most likely put a seal in the top of the filter where it doesn't belong, then it blocks fuel flow. Does this have the small cartridge fuel filter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Green135 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 7:37pm
It’s got fuel supply it was running after I put new filter on just started doing this
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2021 at 10:13pm
i had the same issues with my 615  take a jumper wire and run it from the injection pump to your postive side of your battery and see if it firee
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2021 at 3:47pm
If it stops cranking there is definitely an electrical issue, it shouldn't be the starter if it's just rebuilt. Did you get a new external solenoid? If you boost directly to the starter terminal the starter will not cut out if it is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Green135 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2021 at 11:02am
Haven’t had a chance to work on i will give update as soon as I work on it thanks for all the input
