Series 1 D17 Hydraulic line help
ShieldFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShieldFarm Quote  Post ReplyReply Direct Link To This Post Topic: Series 1 D17 Hydraulic line help
    Posted: 03 Jun 2021 at 9:55pm
New to the forum
I recently pick up a Series 1 D17 (SN 12689) , which is a really nice machine for the price except for one thing. The previous owner decided to remove the hydraulic lines that go to the transit valve, which consequently means my lift arms are deadDead. My major problem in making new lines is which fittings to use. Specifically, which fitting is used to connect the return line to the sump. The service/parts manual shows a oiler type tube ,if so what can I use to replace it .uploads/22126/IMG_20210601_193938823.jpg
Edited by ShieldFarm - 03 Jun 2021 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShieldFarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2021 at 10:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShieldFarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2021 at 10:02pm
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2021 at 6:55am
I have some steel lines I removed from my D17. They have some non-factory bends in them. I would sell them if interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShieldFarm Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2021 at 4:25pm
Would you mind sending me some photos and measurements of the pressure and return lines?
This page was generated in 0.062 seconds.
