200 parking brake |
Mikez
Topic: 200 parking brakePosted: 26 May 2021 at 6:49pm |
Hello everyone.
I seem to remember a post on that topic but I couldn’t find it. Anyone remember it and can find it, I’m sure there’s more then one. Thanks |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 26 May 2021 at 8:47pm |
What's your question/ailment with your 200 ?
btred1466
Joined: 12 Jul 2012 Location: Magnolia, OHIO Points: 206 |
Posted: 26 May 2021 at 9:54pm |
Is this what you are trying to find?
https://www.allischalmers.com/forum/topic178061.html I saved the topic.
Edited by btred1466 - 27 May 2021 at 10:18pm |
Mikez
Posted: 27 May 2021 at 10:32am |
that was one of them thanks.
the other day something went wrong lol. It won’t release now. Couldn’t remember if any post mentioned that issue.
DanWi
Posted: 27 May 2021 at 11:50am |
Do you have one wheel that locked up when you hit the brakes or is the parking brake just not releasing? It could be as simple as a roll pin in your linkage or you could have a spring broken inside the brake or a lining coming apart and doubling up
Mikez
Posted: 28 May 2021 at 7:50am |
just the left brake pedal won’t come back up. Luckily didn’t push all the way and isn’t engaged. It appears the lever is still turning its little shaft
Lonn
Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29819 |
Posted: 28 May 2021 at 10:05am |
I'd say the linkage behind the lever is frozen and rusted. I had a 200 years ago at the dealership where I worked and it had that issue. Had to get in by taking the rear side hood off and taking the linkage apart or oiling it up, can't quite remember as it has been 25 years ago.
Wink I am a Russian Bot |
DanWi
Posted: 28 May 2021 at 6:16pm |
I think just from memory there should be a spring behind the dash to lift the pedal up. Can you pull it back up with your foot or hand? Maybe the pivot shaft for the pedal is rusty, spray some lube on it.
