D 15 final drive |
Page 12> |
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3253 |
Topic: D 15 final drivePosted: 20 Apr 2021 at 7:07am |
About a year ago I found my D 15 has a bent rear axle shaft and a chipped bull gear tooth . I now have a good donor that I plan to put new seals , etc in and then swap the final drive out . I'm sure to have questions along the way . Thanks in advance !
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25275 |
Posted: 20 Apr 2021 at 8:34am |
While a strong strap sling will support it, I made a steel one, bolts to the FD. Made it easier to get the right height and 'angles' to slide it back in.... I have an overhead beam, trolleys and chain hoists...make the job pleasant.... I will take pictures IF I can find the silly 'jig'...... Jay
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 20 Apr 2021 at 11:04am |
And new brakes
ACinSC
Posted: 20 Apr 2021 at 11:46am |
Thanks Jay and Fred . I did the brakes when I pulled the final drive last year . Have the donor bull gear and bearings out now . Next up is the pinion shaft . So far , so good .
john(MI)
Posted: 20 Apr 2021 at 11:59am |
I'm sure you are knowledgeable of this but, you should only do one side at a time. Put it all back together and then the other side.
ACinSC
Posted: 20 Apr 2021 at 3:42pm |
Yeah thanks John . I'm just doing the left side .
ACinSC
Posted: 21 Apr 2021 at 6:36am |
Having a hard time getting the lock ring off the pinion shaft that's behind the brake drum . Anyone have any advice ? Thanks !
MACK
Posted: 21 Apr 2021 at 7:14am |
Cut it off with cut off grinder wheel. Then use new snap ring. MACK
ACinSC
Posted: 21 Apr 2021 at 7:45am |
Thanks Mack ! Didn't think about that .
ACinSC
Posted: 21 Apr 2021 at 2:40pm |
Seems kinda expensive to me . Agco lists that lock ring for $22 . Still don't have mine off but haven't cut it yet . Thanks
jaybmiller
Posted: 21 Apr 2021 at 3:01pm |
been looking at the drawings, the snapring seems like an 'infernal' one.... maybe 2 slotted screwdrivers, to pry it up ,once you get it started, 'tease' it out of the slot ? Never had mine that far apart..... it looks easier than doing my taxes though..... 4 hrs labour AND I had to pay.....
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 21 Apr 2021 at 4:12pm |
Jay Those 'F n T' keys do look similar, don't they ! F..N thing. G |
ACinSC
Posted: 21 Apr 2021 at 4:24pm |
I actually have my favorite son's lock ring pliers . Haven't done the trick yet , but I'll keep trying .
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 90908 |
Posted: 21 Apr 2021 at 4:50pm |
ALLIS did not make snap rings ... they bought them as hardware.. Do the same.
ACinSC
Posted: 21 Apr 2021 at 4:59pm |
Yeah Steve . Plan to ask Brenda if they have a generic lock ring when I order the bearings and seals . Thanks
steve(ill)
Posted: 21 Apr 2021 at 5:14pm |
ALLIS will charge 5 x as much as you can get one at the hardware store.
ALLIS did not make bearings or seals either.. Edited by steve(ill) - 21 Apr 2021 at 5:14pm |
ACinSC
Posted: 21 Apr 2021 at 5:18pm |
Have wondered if Napa could match bearings and seals if I have a number ? Thanks
WeisAC2
ACinSC
Posted: 21 Apr 2021 at 7:13pm |
My favorite son posted a picture for me . Hard to believe that something this size could be bent . This is the good one . Thanks
jaybmiller
Posted: 26 Apr 2021 at 6:16pm |
Jay
ACinSC
Posted: 26 Apr 2021 at 6:54pm |
That's a nice setup Jay . I'll just use the wide strap I have . I'm still redoing the donor final drive and a long way from installing it . Thanks for sharing !
ACinSC
Posted: 29 Apr 2021 at 10:54am |
Finally got the lock ring off . Came off easy after I cut it , like Mack suggested . Now to remove these 2 bearings and the seal . Thanks !
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 30 Apr 2021 at 9:24am |
Google Motion Industries store locator. Take your old bearings and seals with and they will match them up. The best 'bang for your buck' in my opinion. |
ACinSC
Posted: 30 Apr 2021 at 11:17am |
Thanks , Charles . May check them out if I can ever get this last bearing off .
jaybmiller
Posted: 30 Apr 2021 at 11:27am |
FYI the seals on the diff case where the axle goes in are National #471765. You can put TWO of them in place of the 'wider' OEM ones. This should prevent oil from getting onto the brake shoes.... Sad thing is I have 2 sitting here in front on me....
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1011 |
Posted: 30 Apr 2021 at 11:48am |
The seals Jay mention can also be had as SKF 12458. I only used one per side and had no leaks... been several years now.
jaybmiller
Posted: 30 Apr 2021 at 12:38pm |
I tossed (er, carefully installed...) two in per side on the theory they'd be on 'new' part of the shafting, 2 is better than 1 and ,well, only $4 a piece and I 'hopefully' won't ever have 'wet' brakes again.........
ACinSC
Posted: 30 Apr 2021 at 12:41pm |
Thanks Jay and Eric . Think I bought a extra seal last time . Now if I can only find it .
jaybmiller
Posted: 30 Apr 2021 at 12:45pm |
2nd drawer down on the left... er. no, 3rd drawer, hmm maybe 3rd on the right no wait, it's on the btm of the right upper cabinet,yeah, a um... dang ! 'someone' removed that cabinet to make room for 'stuff' from next door. sigh...... NOW I know WHY those seals are in front of me !!!
ACinSC
Posted: 30 Apr 2021 at 2:31pm |
Maybe we're on a different page ? My old seal is National 50055 L 60 . Gonna check the Agco site and see what they list . THANKS !
Page 12> |
