turbo
youngorange2000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote youngorange2000 Quote  Post ReplyReply Direct Link To This Post Topic: turbo
    Posted: 17 Apr 2021 at 8:37pm
will a 426 turbo work on a 301? the 301 is in my 7020 that has been turned up on the pump only reason I ask as the local salvage yard has a pretty nice 426 turbo
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 9:04pm
Sure it will work, but not correctly. You won't like it, as the spool-up factor will be way too slow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 6:37am
An out of the box 3 LM may work for you better
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 1:38pm
NO! A 3LM466 is not a good match for a 301 in a farm tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 1:41pm
Gottcha Ed , wasnt sure as he said it was turned up - so scrap my idea !
nick121 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nick121 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 4:12pm
Likely not too expensive to get the proper new turbo for it. Then it's sized correctly for the engine and driveability
groundhog55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote groundhog55 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:25am
I have a RAY JAY turbo for a 301, has very few hours on a rebuild. Can have it for $200.00
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 7:27am
Problem with a Rajay brand is nothing connects up like an Air-Research. Oil lines and crossover tube all different. 7020's never came with Rajay's if I remember right.
Edited by DrAllis - 19 Apr 2021 at 7:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 8:09am
It would be better to put the 426 turbo on than the 3LM466. I've ran across so many people thinking it would be good, and it has it's place, but on a 301 farm use tractor, it is way too big! The correct turbo for a 7020 I believe is slightly different than the other non intercooled 301's, not sure what is different about it.
