1350 cult hydraulic wing cylinder
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: 1350 cult hydraulic wing cylinder
    Posted: 16 Apr 2021 at 7:24am
Need to reseal a 3.5" X 16" wing cylinder, what is the purpose of the two 1/4"x 1/2" bolts w/flat washers that screw into the end of the rod guide or (end cap)? I see the retaining ring in there witch looks like fun to remove ! Thanks Dave
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 11:14am
Take them out then push the end cap in to remove the retaining ring
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 11:41am
Ya Alvin I see its to hold that end cap in the correct position after you re-assemble the clylinder. Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2021 at 11:58am
Yes it keeps the cap from going in when you use the cylinder
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2021 at 7:34am
Going to have to dip my toe in this water one of these days. Have quite a few cylinders with issues around the farm. Always so many other 'more important' things to do.
This page was generated in 0.453 seconds.
