Allis B rocker arm bushing question
Jcone1025 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B rocker arm bushing question
    Posted: 24 Mar 2021 at 7:48pm
Hey everyone. Still plugging away on this B. Bought a used rocker assembly for it and had a question. I noticed that the bushings in the rocker arms have holes that have been installed in any random place. My old rocker arms had the holes in the bushings installed toward the oil hole in the top of the arm. Any harm in those bushing holes installed opposite the oil hole in the arm? Thanks.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 8:22pm
Bushing holes should be in line with arm holes, as oil comes out of center of rocker tube through the arm to oil valve stems and guides.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 8:49pm
How about drilling a new hole through the rocker arm oil hole through the bushing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 9:07pm
Haven't tried boring a new hole, would probably be ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2021 at 9:30pm
Drilling would be a better idea than trying to pound it out and reuse it. ... Hole on the bottom does nothing, and dont hurt nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 7:29pm
So if I spray down through the rocker hole, it comes out the bushing hole no matter where that bushing hole is located. The way the rocker arms are formed allows for a void around the center of the bushing that oil could flow. Should work I guess. Still drill a hole?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 7:35pm
I would prefer to have the oil DRIP thru the hole right onto the shaft... and not assume it will run under the shaft and wick back up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 7:47pm
Ok yea understood. I’ll drill some 1/8” holes down through the arm holes and figure a way to remove the burrs after drilling .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcone1025 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2021 at 7:48pm
Thank you again Steve.
