c waterpump pulley removal
tc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tc Quote  Post ReplyReply Direct Link To This Post Topic: c waterpump pulley removal
    Posted: 08 Sep 2010 at 3:46pm
Hello,
trying to put new water pump in, any ideas on how to get pump pulley off, i've taken adjusting bolt nuts off, do the bolts also come out?  thanks
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 3:50pm
Thought the 4 bolts that hold the fan on also capture the pulley. It seems as though they stick fast, but I do not remember taking the pulley apart at the adjusting nut.
It has been a while and CRS has set in, so I could be wrong.....
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 3:52pm
On my CA I just took the four bolts holding the fan on and wacked the pulley and it came off. I'm sure My WD45 came apart the same way. you should not need to take the sheve adjusting bolts out.
tc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tc Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 5:51pm
finally got it using block of wood and hammer, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:18pm
If at first you can't fix it, get a bigger hammer. LOL
