WD spindle
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Topic: WD spindle
    Posted: 22 Mar 2021 at 7:54am
The front spindles require bearing spacers. My question is are they on there already, or what looks to be spacers just part of machining the spindle.
  Tim
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 8:02am
The spacer is there. I have a couple of threads regarding this. You can see a spindle without the spacer in. Going to post an update in the gauge wheel thread directly.
Here is a link to the spindle removal thread, it doesn't really show the pieces like I thought. I'll take a picture of the parts and post it here in a bit.
Edited by IBWD MIke - 22 Mar 2021 at 8:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 8:20am
Here is a picture of the spindle, (welded in a piece of plow frame) the original spacer in question, and the additional one I needed for the gauge wheel.
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 9:01am
Tim, maybe this will help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 9:24am
Thanks both of you guys. I thought those bushings that are on there are all I needed. Mike , when you got the spindle block off, can you see the seal up in there to change out.
  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2021 at 9:37am
Tim, I never removed the spindle block. Pulled the spindle from a junk pedestal that was just sitting on the ground.
