gaining trans oil on d17 iv
Brian NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian NC Quote  Post ReplyReply Direct Link To This Post Topic: gaining trans oil on d17 iv
    Posted: 07 Sep 2010 at 8:20pm
I am losing hyd. oil and gaining trans oil. Is there a seal between power director / hyd sump other than trans input shaft seal. Where can i get these parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 8:24pm
I believe there is a seal on the pto shaft that seals between the two compartments.   I'm sure someone else will chime in.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:50pm
It is the input shaft seal that needs replacing.  AGCO carries them.  You will have to split the tractor - might as well replace the other seals while you are at it.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 9:29am
Your problem is most likely the PTO shaft seals there two of the placed together with the lip in opposite directions. The input shaft is up high enough that little if any oil will gravity through. You can get leakage through the input shaft on tractors with hydraulic power director cluthes, because of worn or broken seal rings.
Pullin With AC
