One Sixty injector pump ??
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Topic: One Sixty injector pump ??
    Posted: 07 Sep 2010 at 8:06pm
Working through various items on the One Sixty I bought and finally got a chance to start it this weekend.  Found a leak in the fuel system and appears to be coming from the gasket under the control cover on the injector pump.  Thought at first it might be an injector line.  I don't see obvious bolts or screws but looks like a couple fasteners could be holding it on.  Is there external cover screws or are they internal and requiring the pump to be taken off and disassembled?  Thanks for any help or advice.
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 8:35pm
Is it a CAV pump ? a photo would help on this one
160 CA 920diesel 5020 HD-3
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:01pm
that is a CAV DPA pump. The top cover is held down by 2 acorn nuts on the top, between the throttle and shutoff levers. Those can be a pain in the rear to get sealed up. If you take it off, be sure to look at the position of the governor spring on the throttle lever as well as the governor lever. good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:20pm
Thanks for the info.  I'll get a picture or two tomorrow after work and post, first diesel tractor I've dealt with and want to make sure I don't mess up timing, pump, etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 8:37pm
Here is a pic of the pump.  End cap does say Lucas CAV on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 9:02pm
It looks to have been rebuilt within the last few years based on the DELPHI tag.
