gaskets
shadrake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shadrake Quote  Post ReplyReply Direct Link To This Post Topic: gaskets
    Posted: 07 Sep 2010 at 10:16am
I am restoring a old A/C WD-45. I am in need of some various gaskets from the transmission area. does anyone know of a good source to purchase various gaskets for a 1954 wd-45?
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 10:42am
Haney equipment athens al.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 11:23am
Go to your local auto parts store and buy a roll of the appropriate thickness material. Get a pencil, a scissors and a ball peen hammer and make your own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shadrake Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 12:55pm
thanks, thats a great suggestion!  I will stop on the way home today and get that material and cut my own!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:10pm
If you can lay the material over the mating part and keep it in place, just tap around all holes with the ball end of your ball peen and it will cut out holes.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:18pm
Fruitloop Box works good
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:29pm
Now your giving away secrets used on British cycles for primary gasket, serial box opened up to give larhe gasket. tap around edgeswith hammer to mark outline , tap at holes to mark them and cut out .  Goop with favorite gasket cement/sealer and put in place.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:34pm
Sorry Coke. LOL I don't use the tap around hole method much. I have a set of hole punches made when I did tool and die work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:54pm
Dang guys and fancy tools , had to leave mine behind when i left the maint shop , then when I came back as Foreman there and later closed the shop the dang plumber stole them .. LOL  Oops ment to say plumber got them before i did
Edited by Coke-in-MN - 07 Sep 2010 at 3:56pm
Doug northern IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug northern IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:51pm
gasket paper ball bearing over hole tap or hit with hammer perfect bolt hole
