model M crawler
mike goucher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike goucher Quote  Post ReplyReply Direct Link To This Post Topic: model M crawler
    Posted: 06 Sep 2010 at 10:23pm
Hello I am looking for a parts source for the steering clutches and seals for my model M crawler. Any help would be appreciated. Thanx mike
Gary(OR) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(OR) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 10:57pm
Hello Mike, for clutches, click on the link below. He may be able to help with seals also.
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 1:35am
Mike there are no seals as such in the rear end, depending on serial no there maybe on the later ones but the early ones certainley upto 1940 they were sealed around shaft by a gland pack nut with felt spiral inside if the oil seeped out u just tightened the nut up on the gland 1 notch at a time. h t h
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike goucher Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 10:09pm
Thanx for the info guys!! I found all of the clutch parts on the website you suggested. And giving the existing seal a little TLC shouldn't be a problem either.
mike
This page was generated in 0.151 seconds.
