Best paint for rims?
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Topic: Best paint for rims?
    Posted: 05 Feb 2021 at 11:46pm
I need to paint some rims, both AC and other brands, silver color.  Anyone have a good paint brand to use that holds up well?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 6:25am
I use Ford Argent Silver. I think it is very close to the original rim color. I'm sure there are other options that are good, too.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 7:32am
Rustoleum Hammered Aluminum is what I have used. Levels out well when applied with a brush and is quite hard when dry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 7:47am
John,
I would agree with Greg. I like the rustoleum products. I use rattle cans.
We need pictures too!
mruhlig77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mruhlig77 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 8:15am
I have used Allis grey primer and /or rustoleum paint.....both are easy to match later..If it needs to be shiny...use an aluminum paint over as suggested....
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 1:05pm
Agco pearl gray.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 1:24pm
rustoleum, painted my 210 wheels & rims over ten years ago & they still look as good as the day i finished them
DIESEL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DIESEL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 9:52pm
I used Rustoleum aluminum, it looks great.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 11:34pm
I painted the rims on the 1955 WD45 back in 1976 when I first got it. Rustoleum primer and then their silver paint. They still look OK, but they rotted out from the inside out. Replaced them about a month ago with new rims. I hope these last another 70 years. Oh well kid probably won't be able to buy gasoline in 70 Years.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2021 at 11:38pm
I painted mine with a product called liquid aluminum. It was had to paint but covered vary well and has held up. https://www.agrisupply.com/aluminum-paint/p/81758/
Edited by Dakota Dave - 06 Feb 2021 at 11:43pm
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 9:08am
I use CaseIH silver. Real close match. Painted front rims yesterday with rattle can.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2021 at 11:38am
I had good results with hammered aluminum paint also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2021 at 4:00pm
Thanks for all the great advice guys!  The project right now is a Ford 6000 that had a bad tire and the wheel was loose on the axle, and the wheel seal was leaking.  Decided I shoud fix it all at the same time.  Of course the wheel seal is somewhat difficult to find, although I haven't called New Holland yet.  CR still makes them but none in stock nearby, $68!
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 5:31pm
I think the best way is to get it powder coated and not very expensive. But you have to disassemble so a bit of extra work.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 8:13pm
Dem-Kote spray can paint makes a great Aluminum(silver) paint. Apply it in very thin coats from a 12-18” distance. It’s nozzles allowed 360 degree movement allowing horizontal side to side to vertical up & down spray patterns.
https://www.grainger.com/product/DEM-KOTE-Dem-Kote-Spray-Paint-in-Gloss-6FGH9
Edited by AC7060IL - 09 Feb 2021 at 8:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2021 at 8:21pm
I should have said that all my rear rims are now powder coated. Have a real good local place. Still use the CaseIH silver. The raddle can paint job I talked about above was cream and silver front rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 8:49am
Who does your powder coating Calvin?
Orange Day Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Day Farm Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2021 at 5:17pm
I use mist silver power coat same as Calvin, best overall finish and very durable.
Orange Day Farm
Clint Worron
30' United, 37' WC, 38' B, 41' C&80 Series cultivators, IB, 51' CA, 42' WF, 49' WD,53' WD&cultivators, 57' WD45&33 Picker, D12, D15HC, 180, All Crop 60, 444 baler, etc...
Sanchez View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sanchez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 7:54pm
This wheel was pretty heavily rusted on the inside and needed some cutting and welding around the valve stem. After the repair I had it galvanized at a local shop . I'm pretty happy with the result, the chemical process removed the rest of the rust and restored the factory finish.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 9:06pm
That’s real nice. I believe they were galvanized from factory.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 10:26pm
That looks real good and will last a lot longer than paint!!  Which shop did you use??
I've got a couple from a 'B' I need to do.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 10:28pm
Had mine sandblasted and powder-coated.
Immediately after sandblasting, I took them to the powder-coating place.
I don't recall the exact color; it was some silver that the fellas at the powder-coating place had a "chip" of.  The powder coat cost was very reasonable at $80 for both rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 10:40pm
Great work guys. I’ll have to inquire locally about powder coating. Your $80/rim seems reasonable. Thanks for sharing,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sanchez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2021 at 10:54pm
The shop in Edmonton is Daam Galvanizing, their minimum charge is $90 for 100 LBS, so 2 rear wheels from the WD45  are pretty close to that . As rusty as mine were I figured I would need to sandblast prior to paint , in order to galvanize I wire wheeled the heaviest rust off, then the chemical treatment took care of the rest.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 6:25am
That's an awesome looking D17!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2021 at 6:51am
Good looking rims and tractor! John and all of us are getting some good rim options. The take it all apart, repair and sandblast is the best starting point for the coatings. I like the powder coat look on the D17, more of a argent color.
