gleaner 226 motor/combine parts
Randy(Mo) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Topic: gleaner 226 motor/combine parts
    Posted: 25 Jan 2021 at 9:21pm
Parting out E gleaner, motor, header and any other parts you need, combine will be going to scrap, except motor, if nobody needs parts. this motor will also work in a d17 or wd tractor. text is best or call 573-690-3033. message will also work. can deliver smalls to Boonville swap meet on March 5 or 6
Mo Allis Club member
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 8:14am
Have often wondered this:
Will a WD or WD-45 'W Series' motor bolt up in place of a D-14, D-15, D-17 'G' Series Motor ?
G
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 10:05am
Will fit WC-WD-WD-45-D17.  Will not fit a D14/15.
I've parted three Gleaner E's and all engines went into tractors
Will have to or should use a tractor governor
Edited by Calvin Schmidt - 26 Jan 2021 at 10:06am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 4:22pm
So that means a D-17 is a 'W' engine ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy(Mo) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2021 at 8:30pm
Motor is sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2021 at 11:32pm
No it's not a W engine. It is the same on the rear so it will bolt into WC/WD/WD45 chassis but the problem comes at the front end as D17 used longer pulley. There are "work arounds" but not just "bolt her in". I believe they are "G" engines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 6:41am
W-201 and W-226 are from WC-WF-WD-WD45. The G-226 was from D-17's-170-175.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2021 at 8:03am
Thanks Dr.
So a D-17 G 226 will bolt up to a WD Torque Tube, but some mods are required at the front in order to install in a WD Eg crank pulley.
G
