Help identify my B - partial s/n?
Greg (Hillsboro, OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Topic: Help identify my B - partial s/n?
    Posted: 05 Sep 2010 at 10:37am
I have a B and am trying to identiry it's year and complete serial number.  I'm having a hard time reading the s/n.  It is B7452_.  I'm not sure if that's the complete s/n or if there's another digit following I can't read.  I've attached some pics below and thought that maybe some of you guru's could help.
If it's 7452, then it's a 37, but seems a bit newer that that based on things i've read.  if it's 7452_ then it's a 1947.
It has hand brakes, no electrics at this point other that it has the generator bosses and a bracket there.  No battery box, underhood muffler, arched front end.
What do you think?  Is there any way to put something on to remove paint or enhance the numbers?  I don't want to sand as I think it will just make it harder to read.
Thanks.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 10:53am
If it has hand brakes then it's before serial # 52718, and your 4 digit serial # would make it a 1938. Serial # 97 thru 11799 were 1938.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 10:54am
If that is the whole number 1938 it probably would not have a starter motor.
If you add a digit 1947 it probably would have a starter motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 11:00am
I would say those 4 digits are your whole #. With no starter or battery box it would also make it an early model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 11:01am
You could use a steel brush and then go over the #'s with a piece of chalk, they might show up better.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 11:44am
I should have a block serial number too so you can see if it was put together
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 11:45am
Sounds like you might have an old one.
Sometimes just wetting the area helps with trying to read the numbes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 11:52am
Where is the block s/n located?
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 12:50pm
Look at the casting number over the center core plug on the mag side of the engine.
If it is AMxxxx-10, then it is most likely a 1938.
The engine serial number on 1938 year tractors is on a boss at the rear of the engine block, just above the bell housing, and under the end of the head. It should start with BE.
By 1947, the number was stamped on the top of the rear flange that bolted up to the bell housing. They are easier to get to to read, and it should start with CE.
Given the photo and description, I'm banking on a mid 1938 model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 12:57pm
Other clues to it being 1938 are the toolbox hole for a Gemmer gear, no notches in the hood for lights, low seat and it looks like the fenders have the tabs on the inside.
If the engine has the tall water neck, and two nuts holding the valve cover on, the it is an early BE engine, but it could also be one from a later tractor.
The generator bosses confuse me, unless you do have a replacement engine or swapped block/engine....
Edited by GlenninPA - 05 Sep 2010 at 12:58pm
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 1:18pm
  the cast front wheel centers make it a 38 some had 16" some 15" is the clutch pedal cast or fabricated cast pedals came in 39
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 2:04pm
I've taken a couple more pics that may help for the above questions.  The clutch pedal has an am#, so i assume it's cast.  There are two bolts for the valve cover, and you should be able to see the water pump neck.
 I looked for the s/n on the rear of the block, but couldn't see anything.  maybe once I start tearing into it, I might find it.
Edited by Greg (Hillsboro, OH) - 05 Sep 2010 at 2:05pm
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 4:18pm
That definitely looks like a different engine than the one that is in my C. It is a BE series engine, with the engine number on the block runner at the bellhousing. My valve cover has 4 nuts. Yours would be older. What is that block casting number that you have cleaned off in the last pic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 4:45pm
The block casting number appears to be AM-2916
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 6:14pm
That should be AM-2916-XX. What are the last 2 numbers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 6:44pm
Charlie, it's AM2916-13
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 6:53pm
That would mean the block is about 1941.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2010 at 9:02pm
The B looks like a 38 with a later engine. The generator bosses started about mid 1940 when AC came out with the "special" that had lights and starter. Your throttle quadrant is low also, which is the way the crank start models were. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg (Hillsboro, OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 12:59pm
Thanks everyone.  It had been my Dad's, and he said he was told it was a '46.  I knew from the many topics here, that it was older than that.  Once I start tearing into it to get it fixed up, maybe I can see the s/n on the engine.  I see the flat plate on the rear of the engine, but cannot see any numbers.  Maybe with the tank off it will be easier.  I'll have another post soon.  The shift handle popped out of place and I'm not sure how to positon the gears to get it put back in properly.  That's another post though.
This page was generated in 0.127 seconds.
