Say hello to more of my little friends
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: Say hello to more of my little friends
    Posted: 22 Dec 2020 at 6:07pm
Trying to figure what machine they go to!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 8:19pm
Top right corner is a pen...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 8:24pm
Ok but what implement does it go on!!???
Wait let me guess....checkbook?
Pfouts Family Farm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 9:25pm
210536 replaced by 218741 - clutch shaft E563 power unit
 - If this is the bearing in the pic I would think that it is actually 210541 - clutch shaft bearing
802094 - all mowers (WC, RC, B, C etc)
604431 - replaced by 519750 -is a LaPorte part# -models 60-90sa, 90,95,110,112, 66CHd, SDR, 2A, 2E, 4C, 3A, 140, 140-S, 180, 195, C-630
604476 - replaced by 519751 - is a LaPorte part # - models 2A, 2E, 3A, 4C, #4, 140, 180, 140-S, 100SP, 90, 72, SDR, B,C,WC&RC MOWERS, 90, 95 c-630
unfortunately my master parts book is missing the index for laporte that tells what the model abbreviations stand for.  I could guess but I'll leave this to someone else
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 9:36pm
You had a previous picture that showed a "turn buckle" type tube that reminded me of a part we had to replace on a linkage on a 4 bottom 3 point mounted AC "steerable" plow ??
I didn't see that part in your recent pics .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 9:39pm
802094 hold straps to wood pitman
Edited by Mikez - 22 Dec 2020 at 9:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 9:53pm
Well didnt want to repost the same parts again.  The part you are talking about is 802160.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 9:55pm
?? that must be a deep pitman? what machine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 10:04pm
The part that I saw and asked about was on your classified pic, lower right part. Apparently the majority of your parts pertain to mowers though. Hopefully some one can make use of them Wink.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 10:05pm
Thanks!
Also
You said 210536  - -- its 210736
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 10:06pm
Actually after all-crop parts, the most nos is for roto-balers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 10:07pm
Yes that part you are talking about is 802160.  What it goes to I dont know trying to find out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 10:48pm
802160 is also pitman mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2020 at 10:52pm
who knows...bag says 802160, 802160 is stamped on the part
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pfouts Family Farm Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2020 at 5:17am
my bad.... you have to look up in a couple places and I must have changed the number somewhere.
210736 - listed as a bearing - model "cooper only" (I would assume for the cooper oil field tractors??)
802160 - COUPLING - MODELS #5, B,C,B IND MOWERS
BigJake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigJake Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2020 at 6:47pm
LTP-31 - replaced by 340410
LTP-41 - replaced by 340435
Used on the adjustment lever for the moldboard plows.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2020 at 8:16pm
Thanks!
