Charging an 8 volt battery?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: Charging an 8 volt battery?
    Posted: 02 Sep 2010 at 10:51pm
The boys were taking tractors to the Threshermens Reunion tonight and the WD started then died and while cranking it they ran the battery down. So they swapped the new 6 volt out of the WC and it started right up. So now I have the 8 volt to charge, can I put it on the 6 volt charger? I will swap it back tomorrow as I assume the generator on the WD puts out more voltage. It has a mag, but for some reason they didn't want to pull start it in the rain. LOL!
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 11:05pm
The 6 volt charger probably will charge it some but not any where near all the way.
The WD generator is probably a third brush with a cutout, no voltage regulator. Its more of a constant current charger and will charge fully and then some.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 11:42pm
Thanks, the 8 volt was on the tractor when I got it and has worked great up to today.
