AC subsoiler
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: AC subsoiler
    Posted: 12 Nov 2020 at 7:04pm
I'm wanting a snap-couple subsoiler for my D17. My question is are they model specific??  Other words would one from a CA fit a D17???  Thanks in advance Keith so. va.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 8:18am
Any of the snap-couple sub-soilers you find will fit your D-17. There was a No. 3, a No. 4, and the curved shank Oxnard model. Also a model 44 twin shank model, (I have never seen one). Hard as one shank pulls around here I think a 17 would struggle mightily with two!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 1:42pm
The attachments for the CA as well as the D10/12 tractors will not work with a D17 unless you do a bit of modification, the length is shorter. Also the larger D-series tractor need to have the eye curved upward or the hitch will interfere with the bottom of the transmission/rear housing unless the lift links are long enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 2:25pm
OK thats two different opinions from two well respected members here. Anyone else want to chime in???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 5:54pm
I'll second what Paul said...Wink
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 7:17pm
Agree with Paul and Dave the tongue is shorter on the CA,D10/12.Also I have a subsoiler that came with a WD had to notch the tongue out to use it on my D15 so it wouldn't jam up against the housing.Think I remember that the PTO shaft on the WD had to be removed to use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 7:48pm
I'm thinking I have the 'curved Oxnard' subsoiler. Kinda looks like a '?' on it's side, with reversible 'point'.
Whatever it is, it works real good behind my D-14 !!
Now that shop is sold, wife says sell it....heck, she says sell ALL the 'tractor stuff'....
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2020 at 6:07am
My comment is based on the fact that I have never seen, (in person or Norm's book) a sub-soiler for a CA, D-10, 12.
Edit; Looked at the 'Bible' again. It does say the no. 3&4 were available for the CA. Does not say anything about different length draw-bars.
Edited by IBWD MIke - 14 Nov 2020 at 6:13am
