Ac D17 cyclinder head bolts-Help
gordonh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gordonh Quote  Post ReplyReply Direct Link To This Post Topic: Ac D17 cyclinder head bolts-Help
    Posted: 12 Nov 2020 at 12:46pm
I am needing to bolt my cyclinder head back down on my D17. It been awhile since I took it off. I know there is two different size bolts  that fasten it down and there is some studs. Does anyone know what bolt goes where and the bolt s tighten pattern. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 1:21pm
Center bolt hole on the left side is a BOLT. The two holes in front of it and rear of it are the studs.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 3:15pm
Sometimes, a set of manuals can be your best friend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 3:42pm
Numbers 5-6-7-8 are normally studs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 5:30pm
The general rule for tightening sequence is start at the center, and work your way out...Hug
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2020 at 7:42pm
Pretty much what the A-C manual shows.
