D15 front spindle |
Post Reply ![]() |
Pitbull ![]() Bronze Level ![]() ![]() Joined: 03 Nov 2020 Location: Apalachin NY Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Nov 2020 at 4:08pm |
My D15 has the early one piece solid front axle (wide front end).
The newer design has a two piece adjustable axle. The spindles are different - the obvious difference is the ID of inner wheel bearings. Newer spindle may be slightly longer vertically - 12" as opposed to 11 3/4" Can I use the newer spindles that are readily available and simply change the inner wheel bearing? There was one washer at the bottom of vertical shaft. My measurement of 11 3/4" was taken with washer removed. The key way is very badly worn on my spindle. |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54036 |
My advice would be to talk to Brenda @ Sandy Lake equipment, she'd know!
Post Reply ![]() |
