FS: Loader for D10
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Topic: FS: Loader for D10
    Posted: 07 Nov 2020 at 3:11pm
I have full hydraulic Henry built Industrial loader for a D10 available.  Sells with everything as removed for $1000 or trade for something I'd find useful. I need some tires of various sizes, wheel weights for smaller 100 series CASE tractors (the 75 pounders, casting #G-1092), a 3 speed 727 from an 89-90 Dodge diesel or maybe something else.  Cylinders were not leaking. Pump drive broke than I found out all of the other problems the tractor had and the tractor became a parts tractor.  Located in Maryland, very near Gettysburg, Pa.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 3:50pm
Paul, is that a L-99 loader?  if so, I have the manual for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 7:49pm
This is a HENRY built loader, for the D10 tractors. The tag shows the model number to be L-IC2.  The L-99 is a later Allis built loader.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 3:39pm
The L-99 was also built by Henry.  Mine has a tag saying "Manufactured for Allis-Chalmers Mfg. Co. by Henry Mfg. Co.  I believe mine came with my Series II D-12 when it was first purchased c. 1963.
Allis Chalmers didn't acquire Henry until 1968 (according to Swinford's book).
My L-99 looks a lot like the one in your pictures except that it looks like your bucket is narrower (the L-99 material bucket is 60 inches wide).
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 7:07am
As the tractor that was under this loader is in the 1959 serial number range, This was most likely a "cleared companion" loader before Allis Chalmers became financially involved with Henry Manufacturing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2020 at 3:50pm
still available, make an offerSmile
JJZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJZ Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 6:56am
Do you still have this loader
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 7:55pm
Yes, it's still available: PM sent.
JJZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JJZ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2021 at 5:58am
Hi Paul my name is Joe if you can give me a call at 717-939-8320
