D17 IV overhaul kit
Craig from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig from IL Quote  Post ReplyReply Direct Link To This Post Topic: D17 IV overhaul kit
    Posted: 31 Aug 2010 at 8:21pm
What's the best overhaul kit for a D17 IV gas?  Craig
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 8:47pm
An AGCO "170" motor kit.
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:43am
i can get the 170 kit complete for 650$
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 7:55am
An AGCO kit is 4 inch bore and 8.0 to 1 compression ratio....all after market 4 1/8" bore are less compression.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 8:52am
An AGCO kit for $650 would be a no brainer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig from IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 10:30am
D17brown, where or who do I contact?  Thanks! Craig
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 3:16pm
I would rather have the D-17 overbore than a little higher compression. A D-17 with an overbore puts more power than a stock 170.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 6:27pm
Call Bill, Brenda, or Betty at Sandy Lake Imp. I would go with the 170 kit. The aftermarket over bore kits give a WD45 compression ratio so I'm told.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 8:43pm
Some facts.....a 170 would actually produce about 4 to 5 more HP if you removed the live hydraulic pump and installed an old D17 belly pump. The D17 IV was never Nebraska tested and in reality would only produce about 48 or 49 HP compared to an old 1957 D17 that was tested at 53 HP. M&W made an overbore 4 1/8" (no longer available kit SP48) that was 7.5 to 1 compression( made 57 HP) vs a std D17 that was 7.25 to 1 compression and 4 inch bore (53 hp). You will not be disappointed with a 170 kit in a D17.....you will be disappointed with any aftermarket overbore kit if it isn't at least the same compression (7.25 to 1) as a D17 and I don't think there are ANY out there that are. I believe them to be 6.5 to 1 or thereabouts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig from IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2010 at 8:52pm
Thanks for all the input guys!  Craig
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2010 at 12:39am
craig, my number is 5635420673
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 12:20am
I remember having this discussion some years ago. I'd go with the 170 kit. The higher compression will get you more than the 1/8" overbore but I couldn't convince a few here back then.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 7:01am
And more economical/fuel efficient than an overbore/lower compression kit.
Jon(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jon(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2010 at 1:39pm
Could this kit be used in a wd-45 ?
Clay Bragg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Bragg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 3:55am
dont you also need 170 camshaft for best results?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2010 at 8:52am
Kit could be used in a WD45 ( won't be able to start it without 12 volts and will stress the crankshaft for hard farming use) and a 170 camshaft grind is the SAME as a D17.....175 cam had a different grind for more valve lift.
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 6:44pm
Well how much higher does it put the comp ration on a WD 45 then? Meaning, is it well beyond  87-93 octane will do to prevent knocking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 8:42pm
Compression ratio on WD45 is 6.5 to 1..........D17 is 7.25 to 1......170 is 8.0 to 1......all run on regular gas and the D17 and 170 are timed at 25 degrees BTDC at full throttle where the WD45 is 30 degrees BTDC.  I'd run 89 octane if it was mine, but no need for any better than that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:28pm
The specs say the Gleaner E engine with Z code had 8.1 comp ratio.
But if I read between the lines correctly, the easiest way to get max HP using stock AC parts - is to drop a 175 gas engine into a WD 45. Sound about right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 9:42pm
Yes....good luck finding one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 10:00pm
LOL! Appreciate that fact. Thanks for the info. This thread has been very informative.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 7:30am
I put a 175 kit (8.25:1) in brother's D17 back about a dozen years ago. Worked great. At D17 rpm of 1650 it dynoed at 56 HP before a complete break in period. Never had it on a dyno since cause he after a year or so dropped in a hopped up E engine to satisfy his pulling fever. Thing is after he did that he never pulled it for lack of time but before with the 175 kit he trophied all the time. That was a fun project, we just made our own jig to weld H Farmall top half of connecting rods to the bottom end of the D17 connecting rods. Made the jig by eyeball work only. Then attached Chevy 350 4" bore pistons to them. Compression was so high that on pump gas when you'd shut off the key switch it would make no difference as the engine would run and sound like it did with the switch on. Brother then got nervous and pulled the coil wire which did nothing. Had to shut off the gas. Bought airplane fuel and that did the trick. That thing really cackled loud with the 3" straight pipe he put on. Only cost were a gasket kit, used connecting rods and new 350 pistons. We just reused the old bearing as they looked good. Still has the engine on the shelf and we just talked about dropping it in a WD and to actually see how long it holds together if we go pulling it. OK I veered of a little.
Edited by Lonn - 08 Sep 2010 at 7:31am
Wink
I am a Russian Bot
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 10:02am
Are the 175 and the 170 the same compression ratio?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 10:09am
Almost...8 to 1 on all 170's and 8.25 to 1 on the 175's.....the 8.25 to 1 compression caused the ignition timing to be set back to 23 degrees BTDC versus 25 degrees BTDC due to detonation issues.
