Dayton/ split rim to regular rims = class 8 truck
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Dayton/ split rim to regular rims = class 8 truck
    Posted: 15 Oct 2020 at 12:05pm
Looking at a Dodge 800 big truck, it's got split rims/ Dayton,?? - and wondering if anyone on here has experience in swapping them with newer style rims ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 12:29pm
22.5 dayton center(Open) wheels replace 10.00x20s  24.5 similarly replace 10.00x22s Simple as roll one off roll one on, may have to buy new spacers for in rears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 12:31pm
hmmm.... Simple as roll one off roll one on,
bet you HAVE to open the wallet first though Cry
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 12:44pm
All it takes is a wheel tire change, can buy used Tubeless Daytons at nearly every wrecking yard on existing equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 12:59pm
Thanks for the replys, don't seem too bad then, what was the reason for split rims, I know everything at one time had them , but I've never heard anything good about them , the shop we went too as I was a kid had a hole through the roof by one coming apart,, and a cage all bent up from them
Edited by DougG - 15 Oct 2020 at 1:02pm
Phil Stier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil Stier Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 1:43pm
This scan from the 1949 Budd Wheel catalog illustrates the dangerous 2-piece "split rim" (also know as the "widow maker") is the Firestone Type RH-5.
 The dominant feature of the RH-5 is the attachment of its halves near the wheel's center line. This connection point has an overlapping raised band around the inside of the wheel. This band will be seen on all types of RH-5 wheels, whether Budd style or traditional drop-center light-truck wheels.
These wheels can be hard to identify because you can’t really see how they are made while assembled. It’s easier to identify them by eliminating the other possible wheel types. They are not "Locking Ring," "2-Piece" or "3-Piece Wheels" because they don’t have an easily identifiable ring or rings on one side (lip) of the wheel.
 They are not singe piece tubeless wheels because they do not have a dropped center (where the tire bead goes to allow you to work it over the rim for installation or removal). RH-5 wheels became popular in the late '40's (with manufacturers...) and were used extensively throughout the '50's and '60's.
They were last available from Budd in 1972 and from Kelsey-Hayes in 1976. Due to their design, they have not aged well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 3:50pm
Unless the truck has been setting for a long time finding RH 5 rims is next to impossible as no one will work on them since late 60's
  I bought a 48 ford 2 ton and it had 2 of them on it but were bud style with lug nuts - never did change one of those but found other rims .
 Back in late 50's and early 60's changed some of them on a few trucks when working in gas station but most times boss would tell anyone bringing them in to go to a tire shop as he would not fix them
 Any truck tires we did fix we put under the floor hoist framework when airing them to act as a cage to prevent blowing apart if lock ring failed
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2020 at 4:14pm
Saw a man die from a Failed 10.00 22 budd split ring wheel, did not clean the groove well and the ring did not seat back where once was as was determined by the OSHA Team., shop left the remnant chunk of ring that impaled into a Roof Purlin in place and was told was there long after I was laid off.
I take split ring tube types VERY Serious IF even bother to work on them.  In 1981 had one off a customers trailer in Tulsa fill a cage as the ring popped off.
Edited by DMiller - 15 Oct 2020 at 4:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 9:48am
Neighbor worked at a trucking company helping in shop while going to school , 3 piece rim separated while airing up , mechanic was killed - neighbor had over 200 stitches to close up chest wounds and about 2 weeks in hospital ..
 Makes one believe a cage or some restraint is needed when working with tires no matter the type .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 11:13am
Nearly every truck and trailer I have had over the last twenty five years that had tube types went to tubeless as soon as needed tires, rims were destroyed enough to make unusable and or sold for scrap, the tire shops did not care if recycling tube types or tubeless when mounted the replacements, generally thanked me when eliminated the tube types.
Edited by DMiller - 17 Oct 2020 at 11:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2020 at 2:05pm
take 2 of the tube type rims , cut them in half bead area to open side , weld 4 pieces together to form kind of clover leaf - great firepit ring , found my son has sold a few of them from my old rim pile of Dayton rims
