Light Bracket for D12-III
Terry/EasternIa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terry/EasternIa Quote  Post ReplyReply Direct Link To This Post Topic: Light Bracket for D12-III
    Posted: 31 Aug 2010 at 8:19pm
My brother is looking for light brackets for his D12-III. The ones that go on the fenders. And rear light bracket also.The left bracket is a grab handle also. D10, 15 &17 seriesIII are the same also. Terry.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 9:55pm
Good luck, they are very hard to find.  Try searching through tractor wrecking yards and you may get lucky.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2010 at 6:06am
I have a D10 III which was missing the rear work light.  I found one after 20 years of looking,,,,walked by this hardly recognizable partial skeleton of a tractor(a I400) and there it was-a light complete with fender bracket and original hardware, no dents, but wiring had been repaired and length was ok.  It was as if someone put that light right where I could see it!  I had been through this salvage a few times looking for other items and hadn't seen it before.  I had a D15 fender bracket that I ground the bottom so it would set on the D10 III fender, used it until I found the correct one.
Edited by JoeO(CMO) - 02 Sep 2010 at 6:08am
armandjones82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote armandjones82 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2011 at 8:35pm
If there are any other way that brands like kc hilites and other brands can fit to that, then it would be much better to really have that one in order to make things well on your light bracket needs. If not, then try to resort it to other options in order to make things work out.
Edited by armandjones82 - 21 Jan 2011 at 11:40pm
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 12:41pm
i WOULD HAVE LIGHTS AND BRACKETS BOTH FOR THAT TRACTOR. 785-353-2392
acdeerboy123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdeerboy123 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 8:08pm
need fenders for a d-12 series III
