lp tank valves
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: lp tank valves
    Posted: 05 Oct 2020 at 12:28pm
I have 2 portable lp tanks that are the size you used see on the front hitch of travel trailers. When toTractor Supply to refill, clerk claimed one was to old, the other the gasket was bad. Are these repairable?
Bought these at an auction for $10.00 each.
Edited by Lars(wi) - 05 Oct 2020 at 12:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 12:36pm
WE go to the local Farm Service center.. They will check the tank, put on a NEW STYLE valve and then refill... assuming the tank is not damaged.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 12:42pm
Maybe part is the state you live in, but its been over 10 years since they wanted a newer type valve on tanks, here in the Land of Fruits and Nuts. Some of smaller propane places would refill if they knew you. Last year one place put a new type valve on 7 or 10 gal tank my son had been using. Was about the same price as a new tank.
More simple things the blood sucking lawyers have got screwed up. Need to be a certified expert to screw a valve or pipe together. Because if you sold it your responsible for for how the buyer uses it, just crazy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 1:03pm
Tanks are not damaged, looks like the newer style valves, the same as what’s on my grill tank now. Maybe the next time my grill tank runs empty, I will swap the valve, and exchange tanks at the gas station, those flunky clerks there will never know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 2:22pm
Local LP sales shop will replace valves but tanks have to be inside a Hydro Test date(Stamped on tanks) or will sell a new one and scrap old one.  They drill several holes in them so cannot be reused.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 2:37pm
  take them to Lowe's or someone that don't refill and do the tank exchange
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 2:40pm
Go to some place one rainy night that has the Blue Rino exchange tanks.  The girl that has to come out in the rain won't look twice at the valves or the date code and it will be cheaper in the long run that having the valves replaced and the tanks recertified.
 Blue rino will do all of the valve replacement and testing before they refill them. They also clean and repaint any tank with the least bit of rust on it.
   Then you can refill it anywhere until the test date expires.
Edited by PaulB - 05 Oct 2020 at 2:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 3:02pm
These 2 are the larger tanks, about twice the height as the ‘tank exchange’ size.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 4:32pm
Probably out of date
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 5:19pm
probably out of luck, too
I am still confident of this;
Wait for the Lord;
Mnfarmboy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 6:30pm
Call the lp supplier in your area, ask who recertifies their tanks for them. If yours are not all rusty and dented you should be able to get them useable .  It used to depend on the size of the tank  concerning the OP valve.
Dave
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 7:19pm
I did the same as you, picked up a cheap partly full tank, then used up the gas.  After that I cleaned up the tank and put on a fresh white paint job, let it cure for a couple weeks then added some barn dirt and took them to a propane place, the guy changed the valve and put a visual inspection sticker on, refilled it and good to go.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2020 at 11:27pm
I've had my RV tanks reverted at the local propane dealer just drop off one day come back the next there Certs for 12 more years and full I think the one I did last year was only $5 more than just a fill. If it fails the hydro test you won't get it back if it's clean and undamaged it will pass unless someone left the valve open on a empty tank forever then it'll be rusty inside and automaticly fail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 12:17am
sounds like i been teach'in ya'll well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2020 at 11:53am
Around here new valve cost as much as new tank with valve
