Wd45 barn fire
Steve g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 barn fire
    Posted: 24 Sep 2020 at 3:35pm
2011 had a barn fire left me with a pile of ashes and scrap iron. My somewhat restored WD45 didn't make it. With all the stuff stored in your barn or detached garage it was a hot fire. One thing that I still have is the block appears to be intact. I have not dismantled it. Meaning I have not removed the oil pan and or taken   the crank out and pistons . The head was cracked about four places. Removed head sent it to the scrap pile been spraying down the top of the pistons rotating the motor over every 4to 5 months couple turns. So looking for all your opinions on whether to scrap it ,sell it ,get the crank out of it only,
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 4:40pm
Neighbor had his Gleaner G burn up, it was a really hot fire, everything was warped and sagging afterwards.
I took the 327 off of it and rebuilt it, now it's on our emergency backup generator.
No aluminum parts were there after the fire and block and heads were just fine.
A little CQB never hurt anybody.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2020 at 4:55pm
If it cracked the head, i would pull the pistons and look at the rings... and crank bearings... then decide if part out or rebuild..  Check crank alignment.. but if it rotates, it cant be too far off, unless bearings gone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2020 at 12:45pm
Completely disassemble it. You need to replace the sleeve seals and cam bearings anyway.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 6:25pm
My uncle had a WD-45 in a barn fire in 1964. It was rebuilt and ran well until his shed fire in 2002. I would have rebuilt it again because he bought it new, however he got serious burns trying to rescue  his D17IV and died 3 weeks later in hospital from a heart attack
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve g Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2020 at 6:33pm
Sorry about that loss
