tachometer
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Topic: tachometer
    Posted: 20 Sep 2020 at 1:09pm
I have a tachometer wondering if it 4 or 6 cylinder. i am assuming it is a combine, hoping I can use it on my WC . I don't know if it 4 or 6 cylinder. The person did not scrap many sixes or big tractors.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 1:15pm
2014 HD Tri Glide
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 2:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 4:37pm
Doesn't make any difference. It got its signal from a speed sensor on the flywheel I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 5:28pm
ok, thanks
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 8:22pm
I had one hooked up a 3208 cat, but #of notches on flywheel wasn't right so didn't register quite right. Don't remember how many notches it takes. Thought I had 12 and it 13 ?            MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 8:48pm
That is a Gleaner combine TACH from a K or F.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2020 at 12:43pm
Looks like the MH's as well. But you have switch so you could read ground speed or cylinder rpm as well as engine rpm. The 79 and latter a electronic read out rather than dial.
Would assume this could read multiply functions if you had a switch and the disc with notches and the reader.
