Stuck Hydrant
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Topic: Stuck Hydrant
    Posted: 19 Sep 2020 at 2:46am
Moved to new place about 5 years ago. Never had a need to use this hydrant until now, and found it stuck shut. Handle won't budge. No telling how long it has sat there unused. Perhaps 15 years?
Any hope of getting this to work without digging it up and replacing it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 4:59am
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 7:37am
Might try putting a wrench on the seal and turn it a little, that might be where it's stuck.
Dusty
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 9:22am
What is stuck, could just be the handle pivot point
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 9:39am
there is a packing nut at the top around the stem... loosen it WAY UP and put some PENETRATING oil on the  inside on the packing and the pivot for the handle... then see if that helps... if not, time to replace all.
Edited by steve(ill) - 19 Sep 2020 at 9:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2020 at 3:09pm
turn water off , with 2 pipe wrenches unscrew top from drop pipe - should come apart , then figure out the problem . Could just be frozen at the head or at the valve at bottom of pipe
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 12:50pm
Was frozen at the head. Tried to back out packing nut, wouldn't budge, so hit it and the rod with some Free All. Gave it a bit, was ready to go at packing nut again with a wrench, but tried the handle again first, and was happy to see the rod let go and water started flowing. Rust and some crud came out too, but it's working normal now. These things are pretty simple once you know how they work.
Now that it's working, that allowed me to take one 100' hose out of the run. That, plus going from house hydrant to yard hydrant, got double the pressure and volume in the bargain. About like going from a BB gun to a .22. Heck of a difference!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2020 at 2:11pm
Now be careful of what you point that hose at. Wink
This page was generated in 0.426 seconds.
