Mower for Allis Chalmers D17
jeffgarc12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Topic: Mower for Allis Chalmers D17
    Posted: 16 Sep 2020 at 8:52am
I have a old mower for my allis chalmers D17 and it has been converted to have a three point hitch on the snap coupler tongue. However, when I hook the mower on the tongue of the snap couple sticks out to far that I can't lift the mower up very far and also the mower is too close to the tires and hits them. Is there a way to move the mower back or am I doing something wrong.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 11:05am
can you get any pictures posted so we can see what your set up looks like?
sound like something is weld up in the wrong place when the 3-point adapter was installed (maybe)
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 7:55pm
Sounds like your conversion hitch is for a CA, D10/12 instead of the larger tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 9:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 10:44am
looks like your lift arms are to short, can't quite tell, but you need about 5 more inches in length.
you can try drilling new holes in the flat stock on the bottom of the draw bar and moving everything back.
Dan
Edited by Acdiesel - 17 Sep 2020 at 10:44am
D15 SER.2 DIESEL
2-720'S D21 Ser. II
Gmc,caterpillar
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 2:51pm
I had a similar issue with some implements and my D17. Started using a quick hitch to push the implement back from tires 6”-8”
D17 Series 1
Allis B- 1939
Allis B- 1945
