WD Battery Box
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: WD Battery Box
    Posted: 08 Sep 2020 at 8:16pm
I'm trying to remember from way back that a WD battery box use to have some kind of insulating cardboard/fiberboard material in the bottom of the metal box to set the battery on.  I thought this was to help protect the battery (insulate it).  Does that sound correct?  If so, I was just going to use an old shingle to place in the bottom of my WD.  Should the bottom of the shingle face down in the box or should the rough or top side be face down in the box?  Many thanks in advance.
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 8:22pm
I don't remember that, I thought they had one on top with 3holes for the battery caps, Just what my memory tells me.
garden_guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote garden_guy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 9:49pm
My one battery box has one on the top... Not sure of the material but some sort of wooden fiber?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 6:25am
Those insulators are made of Masonite board. I have some NOS ones. The upper one did have three hose and the bottom one was solid.
Robert Musgrave View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Musgrave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 1:07pm
I had an original top made from masonite/hardboard--I was very careful to layout the three holes based on the original.  When I put it over the new battery--holes and battery caps didn't line up!  May want to double check on newer batteries.  I do remember there was a tar-like membrane in the bottom of the box.   R. Musgrave
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 2:03pm
My 1950 WD father got new had a piece of masonite/hardboard under the battery and one on top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 2:11pm
The originals were a type of fiber board. Masonite will work fine, I have also used 1/4 inch plywood. The granules on roofing shingles will create too much abrasion and possibly cause problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 3:00pm
I used 1/4 inch under-lament hard board for my WC. just to keep the top posts from jumping up and shorting out on the top.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2020 at 9:35pm
Wouldn't a plastic truck mud flap work? Should last for years.   Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 2:51pm
I use rubber mud flaps for trailers. Trim them down to size and lay them in the bottom of the Battery box. Sorta' insulates the Battery from vibration as well as protecting the bottom of the box. They work great. Have em' in all of my Tractor boxes.....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2020 at 5:51pm
I just got me one of these to put in the bottom of my under mount toolbox on the truck. The only reason I ordered it was the dimensions were perfect for the box and it was cheaper than about anything I could find. It will also let water drain, if it every gets wet inside, and it will keep binders and chains from rattling in the box.
https://www.walmart.com/ip/Achim-Wrought-Iron-Rubber-Diamond-Door-Mat-18-x-30-Black/594202910?wmlspartner=wlpa&selectedSellerId=1148
