d-10 series 3 battery replacement |
Post Reply ![]() |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 475 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Sep 2020 at 3:48pm |
what battery do yall like , with lots of cranking amps , that will fit in the battery box on a d-10 series 3 ???? thanks keith so. va.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5156 |
You're going to get as many different battery sizes as you get answers here. I use a group 22 (sometimes it's called a 522 or 22 for a Ford) There are two batteries that fall into the Group 22 size for some reason. The one I'm talking about is just about the same physical size as a group 1 - 6Volt battery and fills up the box on all the little ACs great. Many also will use a group 26 (just be sure that you get one with the +&- terminals oriented the correct way) ,which is shorter and needs a piece of plywood under it to keep the cables from rubbing in the battery box edges.
thanks paul, this is my sons tractor...... i realized while working on it i gave him the best one here!
Post Reply ![]() |
