Bushings for WD hand clutch
hardwood61 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hardwood61 Quote  Post ReplyReply Direct Link To This Post Topic: Bushings for WD hand clutch
    Posted: 30 Aug 2010 at 9:21am
Anybody have any idea of the size bushings that are used - don't have tractor close by and would like to take them along this weekend.  The clutch handle wobbles severely from side to side so I am guessing that the bushings are missing or wore out.  Even if you don't know the original bushing size can any one tell me the size of the pivot shaft - that way I can buy several different sizes with the correct ID and return what doesn't work.
Thanks!
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 9:59am
I think some of the early ones did not use the bushing.
Some of the early 1950's didn't use them I think.
AGCO can get them but they are not cheap.
I think around $30.00 each.
I'm not at the farm today so I can't get you the size. Sorry.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 10:01am
Pin diameter is .870.  Hand clutch bore is 1 inch.  Bushings were used on tractors with serial no.`s 34450 and up.  Allis part no. for the pin is 223130.  Bushing part no. is 224705.  Two were used.  On the last two tractors I repaired the hand clutch levers.  I ended up pulling the transmission cover, driving the pin out and replacing it with a new one.  The bore in the hand clutch lever was egg shaped and required boring and a custom bushing was fitted.  Good Luck.  HTH
