WD45 Hydraulics Gasket needed
woodman Steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodman Steve Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulics Gasket needed
    Posted: 02 Sep 2020 at 5:00pm
My WD45 has the main hydraulic hook up under the seat. It has an in line and out line. The left side has an adjustment screw. There is a cover on the right side that is square with four holes spaced 1 3/8" apart. I need the gasket that goes under this part. My owners manual does not show this part existing. The photo I took will not upload as it is to big.
Who can I call to get a new gasket? Is there a good material that would allow me to make my own! I could text the photos directly to a cell phone if that would help.
Thanks.   Steve
Steve
Two WD45's
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 5:46pm
AGCO PARTS BOOKS.com...…..WD/WD45 book...….page 282 at the bottom......70223297 for one gasket and 70223332 for the other gasket. That is the optional "Transport Valve" that not every tractor had. Call your AGCO dealer to see if these numbers are good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodman Steve Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 6:01pm
Thank you for the quick response.  I will call tomorrow.
Steve
Steve
Two WD45's
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 7:29pm
My bad. I was looking at the wrong p/n list. Both gaskets on each end are the same 70233240 . Sorry for the confusion.
This page was generated in 0.123 seconds.
