D19 Diesel HP
PA185 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote PA185 Quote  Post ReplyReply Direct Link To This Post Topic: D19 Diesel HP
    Posted: 01 Sep 2020 at 3:35am
I’ve heard some tales over the years about some D19 Diesels that were turned up well over 100hp. so basically I have a 2 part question here.
What is the most HP you have seen or heard about with the factory pump/turbo?
Has anyone heard about any set ups using a beefed up pump and bigger turbo?
So let’s talk numbers. What have you seen or heard?
PS: save the lecture about the bad mechanical stories and what can go wrong. I’m well aware of Budas and their potential problems with longevity. This is just to bring to light the true possibilities of the 262D. I’m just curious, thanks!!
Edited by PA185 - 01 Sep 2020 at 3:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 7:18am
110 PTO HP and the head gasket doesn't last very long at all. From experience.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 7:34am
Dr.  was this an agco gasket w/rings or a custom setup of yours?  I just put our 19 engine back together its in primer right now.  We got the parts from Norm several years ago, the headgasket was a 1 piece job and Don B recommended the agco gasket with separate fire rings.  I got some fire rings from Mack, and we got a different block.   the protrusion is right on so hopefully we will never have to touch it again.  It will get used but not real hard.
Edited by CAL(KS) - 01 Sep 2020 at 7:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 8:36am
This was 40 yrs ago and a stock ALLIS-CHALMERS head gasket on an engine with some hours on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 12:10pm
Terry Wood had a good setup but he was an AC engineer, 110 sounds good for the engine,they just can't handle the abuse
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 12:16pm
I never knew Terry Wood ever pulled a D-19/D-262 engine.  I've seen him pull a 190 XT several times many years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 4:33pm
I got a magazine 5hat has him on a D 19 blowing smoke, don't know if is the right engine in it a 301 would be so much easier to work with
180Puller View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 6:11pm
Back in 1971 the late Henry Moody from Iola,KS had a pretty warm D-19 AC puller..It had pump work, bigger turbo,24.5x32's-etc..Knowing what he pulled against in the 7000 lb class it had to be in the 125-150 horsepower range..Needless to say it didnt stay together very good and the next year he pulled a Mod tractor.....There was a 6 mph speed limit back then and he could run it with the D-19.
Also back in the early 1970's there were (4) D-17 AC diesel pullers in my area that pulled the 5500 lb class....They were from Iola,KS,Bronson,KS,Rich Hill,MO,and Golden City,MO...They all had to be in the 100 horsepower range as they were competitive..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2020 at 7:54pm
Edited by DougG - 02 Sep 2020 at 4:12am
tbran View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 1:07pm
Circa 1972.........  D262 copper head gasket  - oring 'd sleeves   35 mm 4 roller pump
Switzer then staged  turbos -  lots of smoke  7th gear in 5000# 6th gear in 7000
HP ? maybe 200 ? 250 ?  Never burnt piston - indirect injection.   More fuel never increased hp  when we went from 4 roller 31 mm  (220 Pump size)  ...  Zipper Special was named so with reason....  Oh, and used D19  PD clutch to start...  in 5 years replaced final drive, trans, torque hsg gears, crank cam... and on and on  but it was fun...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 5:34pm
Now we're talkin !!!   Look at the lug depth on those tires !!!   That is one of the reasons todays pullers don't have much (if any) rear end issues. The sleds start easier and the tires have a much shorter lug so you can spin them faster, making the driveline last longer. I like the " more fuel never increased the HP" line...………   They say todays very best Super Stock 3 or 4 turbo diesels make between 3500 and 4000 HP at 270 to 300 psi of boost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 6:09pm
.....and splitting the cylinder blocks in half....  it is out of hand.  The fans in the stands can't tell the difference between 'road gear' and 20-30% over.  The sleds turn the "pull" into an inertia challenge.   So many classes, so many rules - MPH classes.... fun factor gone on the local level.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2020 at 6:32pm
Agreed. These SSDiesel tractors I am talking about are turning the rear tires in excess of 90 MPH coming down the track, but they really aren't moving the sled much faster than they did 30 years ago, so the "show" looks about the same to the average person sitting in the grandstands. Only the real gear-heads know the difference.
Edited by DrAllis - 02 Sep 2020 at 7:00pm
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 9:47am
   They allow billet blocks with four main caps and yet they have blown them on the dyno I know for sure.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 11:17am
Pics of Terry Wood on a D19 maybe a diesel, sure looks like a turbo by the exhaust, and a couple on his XT
Edited by DougG - 04 Sep 2020 at 12:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 11:25am
Gggrrrr try again
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 11:28am
Another
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 6:35pm
   Was the hand clutch power director stock???
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 04 Sep 2020 at 9:23pm
Yes. Used the slotted plates for low and the solid  center for high. We bent the metal on the tie bars that dip in the oil so as to sling oil into the plates.. must have helped. Keep in mind, we had nowhere near the hp tractors are making today .  Once Eddie was driving at Union City Tn when the manifold turned red, the exhaust we had enlarged to take a bigger turbo let the bolts pop and the turbo blew the hood off   and the sled ran over it all. The hood was as flat as a pancake, and well meaning people were handing him hot parts as they pulled him off the track.. He was covered with black oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2020 at 5:38pm
   Wow, thanks.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2020 at 8:01pm
Wow!! Now that is interesting and some fun facts. Tractor puller guys have to be some of the most ingenious people ever! 😀
