WD../..WD45
Cobb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobb Quote  Post ReplyReply Direct Link To This Post Topic: WD../..WD45
    Posted: 29 Aug 2010 at 6:50pm
Is the block in a WD the same as WD45....I need to do a little swicth'n around if it will work...
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 7:17pm
They are not the same but the parts from either will fit the other. As a matter of fact, after all the WD replacement blocks were used up A-C furnished the WD-45 blocks as factory replacements for both tractors. So...just because a particular tractor has a block with no side plate does not guarantee its a 226 C.I.D.. Of course there are lots of "sleeper" WDs out there with WD blocks and 45 innards, too. LOL
Matt (NEIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (NEIA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 9:39pm
I know of a lot of people who have WD's with 45's engines in um and vice versa
1955 WD-45 with factory PS
Cobb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobb Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2010 at 9:50pm
Thanks for the replies...I have a 45 with a bad block and an extra WD good block..I guess I could just swap...BUT if I am getten it right ...it might be better to put the guts from the 45 into the WD block ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 8:16am
Yep, I'd say about 7 to 9 HP better.  LOL
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2010 at 12:01pm
Our '41 WC had a dealer installed replacement block installed back in the 50s that was the WD45 type, but it had all stock WC internals in it. Kip
